8-5-2007 |
2.00 |
Left Wing Fuel Sender float wire |
After some thought I decided it should not be too difficult to break out the Oxy Acetelene tanks and weld a section of wire back on to the float wire. I used a small tip and a soft flame to work with the small gauge wire. The weld turned out just fine and is perfectly servicable. Moving on now. |
