Date:    9-6-2007
Number of Hours:    9.00
Brief Description:    Upper Fuse assembly
Spent a long day fitting and fabricating the Upper fuse assembly. Quite a bit of time was then spent on the fitting and drilling the F-771 Forward Top skin to the firewall, ribs and subpanel. Also fit and drilled the F-721C and F-721D attach angles to the panel and the F-721A deck.
