Date:    1-14-2007
Number of Hours:    1.25
Brief Description:    Electric flap assembly
Electric flaps are standard on the RV-7A. A sealed motor/gear drive assembly between the seats provides the power through a welded steel actuator and pushrod attached to the inboard end of the flaps. Drilled out the clevis ends of the welded steel flap actuator. Drilled the safety wire hole and installed the rod end bearing and jam nut on the ES-85615-157 flap motor shaft. Pictures later.
