Date:    3-11-2006
Number of Hours:    3.50
Brief Description:    Complete Rudder with leading edge
With the exception of the fiberglass tips for top and bottom, the Rudder is complete. There's a good coat of primer underneath the leading edge since it's no longer accessible. Bending the leading edge was a bit frustrating, but it came out okay. The eye bolts that mount the rudder to the Vertical stabilizer are visible in the pictures. The center of the eye bolts are set to the called-out distance from the front spar according to the plans. Now moving on to the right elevator.
