Date:    5-24-2008
Number of Hours:    7.00
Brief Description:    Dynon DB-9 serial mounts and panel work
Mounted the Dynon DB-9 serial cables that are used to update the Dynon's from the PC. Happy with where those are located. Drilled the holes for the dimmer switch and the wet compass deviation placard. Began working on the wiring for the dimmer switch.
