4-28-2008 |
4.00 |
Whelen Strobe power supply wires and Seat Belt cab |
Climbed into the fuselage tail cone and torqued the Seat Belt harness cables to 60 Inch Pounds. Next, pulled the shielded cables (left and right) along with the power supply cable under the seats and back to the Whelen Power supply. Crimped a ring terminal to the local ground wire for the Whelen Power supply, then attached this wire to one of the mounting screws. Will crimp the Molex connectors for the shielded wires next. No pictures today. |
