Date:    9-12-2016
Number of Hours:    3.00
Brief Description:    Check prop flange run-out and undercarriage
Removed prop and checked the propeller flange run-out. Found to be 1/1000" inch deviation. OK.
Checked undercarriage legs and found both were bent / twisted. Neither would fully retract. Possibly beyond repair.
RH wing tip has minor buckling which can be repaied.
The cowl flap will require a new skin.
