Date:    8-5-2006
Number of Hours:    4.00
Brief Description:    Right Wing
Remove clecos, debur Rear top skin.Remove clecos, debur Nose skin and Ribs.Measure, cut, drill, and grind holes in bottom of Nose skin for fuel tank vent tube and fuel drain.Begin cork on fuel tank between nose ribs.Fuel filler nozzle is not welded level with tank, need to shim skin for flush cap when closing.
