Date:    6-27-2004
Number of Hours:    16.00
Brief Description:    Preparing canopy frame
Adj Wd716 Ribs for 90 deg Cleco C702 fwd top skin to Wd 716 Fwd canopy weldment. Fit Fwd canopy frame/skin assy on fuselage, check and adj fit several times Taped canopy frame assy to fwd skin and side skin Predrill hole pattern in C614 center splice plate Drill Wd716 thru top skin Deburr and re cleco, drill #30 thru prepunch holes in tabs on ea hinge bracket into fwd canopy frame rib and splice plate Remove, deburr, prime parts Reassemble and install/tape and adj, adj, adj... Drilled hinge brackets and press in bushing, temp attach Wd 620 handle Assemble and rivet splice plate on frame
