1-12-2004 |
6.00 |
Fitting Horizontal stabilizer |
Clamped HS to aft fuselage and measured for perpendicular Drill holes thru HS 908 attach angles on forward spar, outboard holes thru F710C spacer and F710B angle Install F798 shims Set 0 degree incidence with 11/32 drill bit under rear spar of stabilzer Drill bolt holes thru F711B bars and rear spar of stabilizer |
