Date:    9-18-2003
Number of Hours:    5.00
Brief Description:    Rivet aft deck, side rails/gussets
Leveled fuselage, mounted, drilled deck to longerons, deburred and riveted aft deck. Rivet aft skins to longerons at specified locations. So top skins can be fastened to longerons. Mounted side rails(F721B), trimed F757 gussets and drilled. Drilled and polished F636 shoulder harness brackets Started preping bellcrank support assy. Made and installed F786A Top fuselage stringers
