Date:    4-13-2003
Number of Hours:    3.00
Brief Description:    Install vent line, parts on ind rib etc
Install vent line More sealing Install capacitance plate on ourside rib and run wire to inside plate/rib Install/Rivet/seal BNC connector, vent connector/fuel pick up connector and Anti-Rotation bracket on access plate. Made T411 end support brackets. Note: Waiting on 5/16 connector and fuel line for fuel return to be mounted on inboard rib.
