Date:    1-22-2003
Number of Hours:    8.00
Brief Description:    Riveted baffle and mounted Tank
Riveted missing platenuts (5) on inboard spar Cleaned tank Applied sealant for baffle, cleaned and sctch brited baffle. Mounted baffle, blind rivet inside ribs to outside and inside of baffle. (41H) Blind riveted T912 brackets on top of baffle (42H). Riveted tank skin to baffle. Started with squeezers, ended up using pneumatic gun, much easier NOTE: Make machine countersink rivet holes on bottom of skin to spar deeper. Cleaned tank, Mounted tank to spar, not easy.
