1-5-2003 |
5.00 |
fabricated T905, capacitive sender unit |
Fabricated Right and Left T905 brackets Fabricated T915 (2ea) Antirotation brackets Match drilled T905 to rib and outboard rib for T410 Need to fabricate T410, need to find stock. Mounted nutplates on two capicitive sender units for left tank Soldered 15" wire to BNC Bulkhead connector Install out board plate and wire lugs |
