11-26-2002 |
4.00 |
Mounted tank on spar, drilled brackets |
Mounted angle brackets and baffle to spar Drilled out 3/16 holes on bottom of angle brackets Disassemble Drilled and deburred holes for 5 nutplates to be rivetted on spar Assembled both End ribs to tank, Installed baffle Drilled and deburred baffle and ribs Install baffle to tank, tank and angle brackets to spar Looks like a WING!!!! |
