8-3-2014 |
0.00 |
Flight #10 |
• Hobbs: 9.3 to 10.5 = 1.2 hrs • Idling on the taxi way, and waiting behind another a/c, the temps all stayed good! Was able to get the oil temp up close to take-off minimum (I’ve never actually gotten there on the ground) • Ran the engine pretty hard today, generally always above 2,700 RPM. • CHTs and EGTs all good! o CHTs: 347-392. Never once got to yellow caution. o EGTs: 1200-1300+. Never once got to yellow caution. • OAT on all flights was 64 at altitude. I still can’t keep the oil temperature UP. It’s about 158 to 165 degrees. • OP still right at 39-41 psi. • I think I’m running lean, so I ran WOT in level flight and pulled back the mixture. Sonex says I should get an RPM increase. I got about a 40 RPM increase, but I think it should be more. I will try to richen the mixture slightly and see what happens. I’m running full rich on the mixture knob, and still seem to be burning less than 4 gph. At WOT and full rich I should be burning more like 5+. • Did spins again. I’m able to recover in ½ turn with minimal altitude loss! • Right wing is still heavy. I will try adding a temporary trim tab to the right flap and see if that helps. If yes, then I’ll look at adding a permanent trim tab. • Aerobatic Maneuvers: o Did left and right aileron rolls today! The plane flew them great! I do better left rolls. o Full throttle, dive for 120 kts, pull up to 20+ deg and pause, then full stick deflection. o Ended maneuver with slight nose down attitude, 100 kt airspeed, and about 2g’s pull out. o All felt very smooth. Did about 5 to the left and 2 to the right. • Good landing approach. Did not go through runway centerline. • Landed full flaps. Flared a little high and floated a bit. Little bouncy on the landing, but not bad. Easy runout and minimal braking. • Need to work on more landing finesse. • Battery notes: o After the last flight the battery seemed weak o After 3 weeks of no flying (on vacation), I put the batter on the charger. It REALLY needed it! It took overni |
