7-19-2014 |
0.00 |
1 day, 3rd of 3 flights |
July 19, 2014 (Flight #9) • Took off for Fitchburg (FIT). • Hobbs: 7.3 to 9.3 = 2.0 hrs • CHTs 1 & 3 still bumping up an over 400 the first 20 minutes to ½ hour of flight, and when doing multiple takeoffs. Later into the flights, not so much. Mostly OK. • I need to look at tightening up the baffle plenums. • OAT on all flights was 62 to 75 at altitude. I can’t keep the oil temperature UP. It’s about 158 to 165 degrees. • OP still right at 39 psi, but while taxiing for takeoffs at FIT, sometimes dropped to 20psi. Bumping up the idle speed to 1,400 rpm raised it back to 26, but I don’t like idling that high. • Did 4 full-stop landings at FIT. Tried both 20 and 30 degrees of flaps. o I like full flaps (30 deg). Plane doesn’t float so much and my landings don’t “bounce,” if not perfect. • On climbing out, CHTs 1 & 3 kept going over 400, up to 411 sometimes. Had to throttle back some and flatten the climb to only about 250 fpm, which is not pleasant with the tree-covered hills around the airport. • Half way back to 6B6 I spent a full hour just doing air work: o Wing-overs (many) o Zero G’s (just for fun) o 45-60 deg steep turns. Pulled 2.5 to 3 G’s (many) o More L/R spins. I got good entries into them, and I could often get the spin to stop in ½ turn. I let one spin go a full turn before attempting recovery. Recovered right away. I’m having fun with spins! • Took data to calibrate airspeed accuracy. At 2,500 rpm, at 2,500 feet at 62 deg OAT. o Flew 0 deg heading: 79 IAS, 91 GS (via GPS) o Flew 90 deg heading: 75 IAS, 80 GS o Flew 180 deg heading: 81 IAS, 81 GS • Voltage was constant at 11.7 to 11.8. Seems awfully low. Other flights were up at 12.4 to 12.6. I did have some electrical load: o EFIS o Aux (running the portable GPS) o Strobe and Position lights (low voltage LEDs) o Landing light (sometimes) • Landed back at 6B6 • Filled up on fuel. Put in 7.8 gallons. o For 2.4 hours that’s 3.25 gallons/hour! And I hardly ever leane |
