5-4-2012 |
3.00 |
Windscreen - begin installing on fuselage |
- Balanced the left aileron. It was close to balanced when I started, so I did not need to remove much lead. - Finished painting the bow strap. - Peeled the protective plastic of the interior face of the winscreen. It would be hard to remove later, and once installed there shouldn't be much to scratch the inside. - Began installing the fasteners. I can't do the bow yet, since I need the bow strap, and the paint hasn't dried. - I found the machine screws called for in the plans were just too short to work. So I'm using the S50 (longer) machine screws instead. But now I will need to order more hardware. |
