4-25-2012 |
0.00 |
Windscreen - trim & drill |
- With everything in place I noted some tweaks to the trimming that needed to be done, so I removed the windscreen again, cut on the band saw, filed, and then sanded the edges. - Reset the windscreen once again, clamping in place. - Drilled all the holes along the windscreen edges where they meet the fuselage sides. - In photo #3 you can see the Bow Strap that does not reach the fuselage. It is supposed to be just about touching the stringer below. I cut this strap per-plans, many months ago. Since I set the bow higher than the plans, I will need to lay out and cut a new, longer strap. Getting there! |
