4-23-2012 |
3.00 |
Begin install of windscreen |
I got the windscreen and windscreen bow materials today from Sonex. - Test fit the bow. The elongated holes in the upper stringers were a bit too small, and a bit too far forward. - So I spent some quality time with my files, widening and elongating the holes. - Then I marked the center line of the canopy, front to rear (photo #1). That way I could see how the center line of the bow (which I also marked) and the windscreen were lining up. - I used a wood 2x4 and a rubber mallet to bend over the upper flanges of the forward firewall (it holds the fasteners for the windscreen). The fuselage stringer acts like a bending brake, giving a nice straight bend. - Test fit the windscreen (photo #2). No dice. The bow was up too high. - So I cut 3/4" off each end of the bow. - Test fit the windscreen. Still no dice. The bow was still a bit too high. - I cut off another 1/4" from each end, then test fit the windscreen again. Now it fit, at least at the aft end. At the forward end (photo #3) you can see I will need to trim the material at the forward end of the wind screen, until it lies flat on the firewall. - Through the holes in the side of the fuselage, I used a Sharpie to mark where the holes needed to go in the bow (to fasten it to the fuselage). - Took the bow out, then pilot drilled 1/16" holes where I had marked the bows. Then updrilled to 3/32" (they will need to be bigger, eventually). - Put the bow back in the fuselage and held it in place with long reach clecos (see photos on next page). HIT 1,600 HOURS ON THE PROJECT, TONIGHT. |
