5-17-2014 |
3.00 |
Reinstallation of control stick assembly |
Now that I have re-made the pilot-side control stick, I reinstalled the entire assembly. I also had to re-make the connectors for the push-to-talk wiring, as the ones I just re-did last week, had trouble mating. I cut 3 of the 4 connectors off and re-made them with new, slightly better connectors. It was a little more tricky doing all this work from under the airplane. BTW, having the lower forward skin still OFF is a tremendous help in doing all this stuff!! The spar pictures are just to take up space, in case you'd like to see how they come together in the spar tunnel. |
