6-20-2012 |
1.50 |
Install control stick assembly |
- Sonex's callouts for bronze bushings are too short 90% of the time, even with the paint removed. So I do what I always do; I buy longer bushings at the hardware store and cut them down to size. Photo #1 shows 2 cut bushings. The red lines are roughly where I need to get to, so I use my Dremel cutoff wheel to make the first cuts, then use a file and my Scotchbrite wheel to finish up. - Photo #2 shows the bushing in place in the control triangle. - Photo #3 shows the bolt installed, with extra washers to take up the left/right slop. More photos on the next page... |
