2-29-2012 |
2.75 |
Rudder cable + cable fairing + prime paint |
- Finished making a longer fitting to reach from the right rudder pedal to the rudder cable. Right rudder cable install completed, so NOW THE RUDDER SYSTEM WORKS! - Installed the left rudder cable fairing at the rear of the fuselage. Started the right fairing install, but didn't finish. - In between rudder cable work I prime painted the outside end of the aileron. It only has a stripe, matching the wing tip, across the end of it. The photo below is after the first coat. A total of 4 light coats were applied. |
