2-28-2012 |
1.00 |
Left rudder cable |
Installed the left rudder cable to the rudder pedal. - Used a 3/8" drill bit to set the 3/8" distance off the firewall (photo #1). - Marked the location of the clevis hole on the aluminum rudder link. - Removed the link, drilled the hole and deburred, then cut and rounded the end of the link. - Installed with bolts and cotter pins per plans. - Attached the rudder return spring. |
