Date:    2-1-2012
Number of Hours:    2.00
Brief Description:    Water bottles and rod end bearings
- Reinstalled the water bottle cages above the flap tube (before I realized the flap tube went there I installed the water bottle cages too low). They are riveted in place with flush rivets in the dimpled front face of the spar tunnel.
- Per C03, installed the rod end bearings at the ends of the flap and aileron push rods. The rod end bearings all got bronze bushings in them to make the i.d. of the bearing smaller. This was per the alternate hardware on the C03 drawing, and as provided by Aircraft Spruce.
- Spent a bunch of time cleaning up the basement, too. I didn't log that time!
