1-16-2012 |
1.50 |
Flap & Brake handles |
- Dipped the flap handle a couple more times. The red seems to go on thicker than the black. - Assembled the brake handle assembly (photo #2), so it's ready to mount as soon as the flap tube is ready. - Installed some more JB Weld in the elongated hole in the right support braket for the flap support block. I can then drill it out to size and install the flap tube. - Located, pilot drilled then updrilled the flap handle to the flap tube's bracket (photo #3). Had to do some sanding to get the burrs off, so prime painted the areas where the paint was removed. Tomorrow I will paint gloss black. |
