1-14-2012 |
2.50 |
Hand brake |
- Remade the brake handle. Overall length is the same, but I made the bend up closer to the top of the handle so I can use the flap detents for a parking brake. - Then I used "Plasti Dip" to create a rubber handle. Did 3 dips following the directions and left overnight to dry - Not pictured, I also did some rework for remounting the water bottle cages (which I mounted too low on the spar tunnel the first time!). |
