Date:    10-11-2014
Number of Hours:    3.00
Brief Description:    Hydraulic Brakes
Installed the nylon hydraulic lines, wire tied them in place, and installed 3 of the 4 fittings.
I lost one of the nut/sleeve fittings, and they are VERY proprietary and VERY hard to find. I found the sleeves locally at NAPA Auto, but NAPA does not carry the nuts! Unbelievable. So I ordered a few nuts from Texas, and they will be here after the weekend.
The third fitting was one of the two connections to the master cylinder. I could not see the fitting or get to the nuts with the master cylinder installed, so I took out the two bolts holding the master cylinder, pulled it out from it's angle brackets, and was then able to get to the fitting. After I get the last fitting and install it, I'll reinstall the master cylinder.
