Date:    9-30-2014
Number of Hours:    2.00
Brief Description:    Wheel pant work for new brakes
For the new brakes the wheel pants need a larger cutout on the axle-side, and new hole locations for the brake mounting plate. I cut out the opening with a Dremel cutoff wheel, then sanded smooth.
The round disks are .032 aluminum, 1-1/4" diameter pieces, glued in place at the hole locations for the brake mounting plate. This will get covered with fiberglass to hold them permanently in place, to add reinforcing for the anchor screws.
