Date:    8-5-2012
Number of Hours:    1.00
Brief Description:    Assemble wheels & tires
Assembled the wheels/tires. Note that the plans don't give you any information on how to do this, but the Sonex web site does have a downloadable PDF file to explain it.
http://www.sonexaircraft.com/documents/instruction_sheets/wheel_brake_install.pdf
Note that the Sonex instructions are missing some crucial information if you have never assembled an aircraft tire (as I had not). Here is what needs to be added on page 2 under "Assembling the Wheels", between a. and b.:
a1: Insert the tube in the tire. The air valve will point to the outside of the wheel.
a2. Put a little air in the tire so the tube doesn't get pinched by the wheel halves get put together.
a3: Insert one wheel half into the tire. Make sure the air valve goes into the semi-circle cut out of the tire half.
a4: Insert the second wheel half in the other side of the tire, again making sure the semi-circle cut out of the tire half is at the air valve.
a5: [I have the machined brake drums] Lay the brake drum face on the half of the wheel AWAY from the air valve, and align the bolt holes.
