Date:    9-26-2011
Number of Hours:    1.75
Brief Description:    Finished RIGHT forward fuselage
Completed the right forward fuselage tonight. Total time for this fuselage side was 14.25 hours.
- Set all the rivets. MADE SURE NOT TO RIVET THE PARTS THAT MUST WAIT UNTIL WING RIGGING.
- I put masking tape over all the holes that were not to be riveted (you can just see it in photo #3).
- Although nearly everything used a CCP-44 rivet, there were some -42's and some -46's, so you need to be careful to set the right ones.
- Finally set all of the screws in the motor mount angles, rudder pedal assembly and the seat belt attache assembly. Set the torque.
- I didn't put on the red torque seal. I need to remember to do that tomorrow.
Onto the LEFT fuselage skin!
