Date:    6-8-2013
Number of Hours:    3.50
Brief Description:    Wiring P-leads + RDAC
- Finished the engine-end of the P-leads. They are shielded, so I had to include wiring a ground wire to the braides shield, and then adding a connector to the end of those ground wires. Connected the P-leads to the mags, and the ground wires to the firewall ground block.
- Then began wiring the RDAC box. I connected the CHT leads, Oil Temperature and Oil Pressure wires. The EGT wires will go in after the engine exhaust is completed.
