5-23-2013 |
2.00 |
Wire bundles + fuel sight tube |
- Had to reconnect the passenger PTT wires, since I'd run them around the rudder cable. Oops. - Used wire ties and tie string to bundle the wires of the comm harness (photo 1). Makes things much neater and easier to handle. - Started installing the fuel sight tube. Connected one end to the tank fitting (photo 2) with a clamp, then ran the tube through grommets in the instrument panel (photo 3). |
