Date:    5-18-2013
Number of Hours:    1.00
Brief Description:    Wire supports
Here is the end result of the Click-Bond wire supports. You can see in the 3 photos (especially #3) that the actual part is quite small, compared to the contraption that sets them.
Photo 1 has the comm antenna held in place permanently with a quick tie. And photo 2 is holding the LED cockpit light wires. These were thin wires so the plastic quick tie wasn't secure enough on its own, so I used twine made for wire bundling to add more suport so the wires don't slide around.
In photo 3 you can see what one of these Click-Bond supports look like, with the green adhesive around the outside. Here the wires are held loosely in place with string just to hold them temporarily.
I also started splicing the headset wires. The comm radio harness wires for the headsets were way too short to reach behind the seats where I have my jacks, so I need to splice the shielded harness wires to the shielded wires I have coming from my jacks.
