5-16-2013 |
2.50 |
Install Click-Bond wire supports |
Drilled a couple of holes in the structure and added rubber grommets to run wires through. To install wire supports where you don't want to go through the aircraft skin, I saw a demonstration at Airventure last year of these Click Bond fixtures. There are many different types, but I'm using ones designed to accept wire ties. So run the wires across the little fixture and hold the wires in place with a wire tie. CHECK THE NEXT LOG ENTRY TO SEE WHAT THE FINAL PRODUCT LOOKS LIKE. The big huge clear plastic boxes you see here are NOT the wire supports. These are just the plastic framework that holds the little fixture. The actual fixture is down where you see the green cured adhesive, and it's SMALL. http://www.youtube.com/watch?v=eILC78Gkl6o http://www.theflightshop.com/Cataspx2.html The way they work: - Clean surface - Mix adhesive - Put adhesive on base of fixture - Installation device has sticky tape on the 2 legs that straddle the device. Put the sticky legs on the surface and it sticks. - Now press in the center and the plastic center piece clicks down and locks the fixture and adhesive against the surface to bond to. - Wait 2 hours and then remove the big clear plastic installation fixture. |
