5-11-2013 |
3.00 |
More wiring |
Worked on a lot of miscellaneous wiring, including: - The pin connectors from the RDAC would not fit through my firewall fitting so I had to disassemble the pins/sockets, put the wires through, and reattach the pins/sockets on the other side. - Attached the engine block ground cable to the ground bus. - Cut the RDAC power and ground wires to length, label their ends, and attach the appropriate connectors. - Attached the RDAC power wire to the avionics power bus inside the cockpit. - Made a power bus for the engine-side of the firewall, even though I don't have anything that needs to be powered from it at the moment. It's easier to do it now then later, if some power requirement comes up in the future. |
