Date:    3-29-2013
Number of Hours:    1.00
Brief Description:    Mount COM antenna
I got the COM antenna with an 8' antenna wire. The 8' wire limited where I could put the antenna, so I put it directly behind the top of the cockpit. There are a LOT of washers and insulators that make up the attachment. It was pretty difficult to do with only one person!
When running things from back to front in a Sonex, there are NO good place to run the wires, so threading the wire in and around things, and up to the radio, will be an excercise!
