9-12-2010 |
1.75 |
Elevator hinges |
OK, I guess I wasn't quite done with T07. I needed to drill the holes in the hinge halves to be truly done. So tonight I aligned the elevator assembly with the horizontal stab and marked the elevators for the hinge locations. Then I marked the hing hole locations and drilled on the drill press. Deburred, then cleaned the layout marks off the hinges. |
