9-9-2010 |
2.50 |
Right, then back to left, elevator |
I set the center rib in the right elevator, but it didn't lay out right when the skin was closed up. I needed to position it differently before drilling. Soooo.... I made a new rib, reset it, and drilled the top skin holes in the rib. I then went back to the left elevator, which in a previous post I noted didn't look so hot. I made 2 new ribs, set them better before drilling, and got the center rib drilled. The second rib is ready to go for tomorrow. So I'm not much further than I was at the end of last night, but both elevators look a lot better, so I'm happy. |
