Date:    8-9-2009
Number of Hours:    3.00
Brief Description:    Cut 1 wing spar web
Finished cutting out the first main wing spar web PATTERN, then...
Cut out main wing spar web W10-01. Did it with yellow (straight) snips. Now, if you've never tried to use those to cut 12' of .032 aluminum, then you wouldn't know why it took me nearly 3 hours to do it... I've got to try the Olfa or other method.
