2-15-2014 |
0.00 |
My Current Punch List |
Here is the current punch list I'm working through: Add cowl fasteners at hub Test fit entire cowl Finish fasteners at windscreen Finish control surface cotter pins Solid rivets in spar tunnel Paint tail tips Paint cowl Storage compartment Alum cover over pushrod Wheel pants 3rd fastener on R pant Paint Install transponder antenna Transponder test Attached transponder connector Test for static leaks Have upholstery made Fuel flow test Test run engine Rivet lower skins Support wiring under panel Fix oil return hose kink Barber pole stripes behind fuel sight tube Attach spring at canopy slide Re-attach brake cables Repair paint Bulkheads Finish setting rudder hinge Install N-numbers First polish back of fuselage Replace nylon lock nuts with solid lock nuts in engine compartment Seal firewall opening at electric wires Mark fuel quantities on tank Tail low Tail hight Buy ELT Install ELT Get State aircraft registration |
