Date:    8-3-2013
Number of Hours:    2.00
Brief Description:    Rocker assembly
Just got back from Airventure, Oshkosh! As always it was great to see other Sonex folks, the factory folks, and lots of Sonex aircraft. But now it's back to work!!
I worked on three things tonight:
1. Installed the new rocker block for the left rocker assembly, after breaking the original one. But I found a gouge in the stud that holds the rocker assembly on, and I'm concerned about the stud breaking in the futuer. I have asked Sonex about it, so I am holding off installing the rocker assembly.
2. I looked at what is necessary to install the new Sandia STX-165 transponder. I need a Tee adapter and some more 1/4" ID tubing for the static air connection. I also need to have an antenna coax made.
3. I began to remake my fuel tank vent with some JB Weld.
