4-25-2013 |
2.00 |
Cockpit light |
Because of the cramped quarters inside the fuselage it took me 2 hours to measure, make and install a bracket to hold the current limiter for the LED cockpit light. It's mounted to the channel that makes up the spine of the turtledeck, and it was cramped quarters getting up there. Also looked at where the AHARS and Magnetometer will go. AHARS looks like it will fit under the copilot seat, if I make a little shelf for it. Magnetometer has to be mounted as far from ferous metal as possible, so I'll probably make an aluminum shelf 2 bays behind the cockpit and mount it there. |
