3-17-2012 |
0.00 |
Paint, weights, panel, fuel... |
More miscellaneous stuff... - Continued working on the fuel filler overflow pan. Drilled and counter sunk a hole in the "pan" for the drain tube. Drilled a hole in the side of the fuel filler box to run the drain tube out (photo #1). - Took apart and cleaned all the parts that make up my removeable instrument panel (photo #2). - Drilled the 5/8" hole in the upper right side of the instrument panel, for the fuel sight guage (photo #3). |
