Date:    4-26-2009
Number of Hours:    2.00
Brief Description:    Parts Preparation
Worked on bending and cutting F14-09R. I finally got it bent open, but it was a royal pain. Closing angles: easy. Opening angles: not so much. The pry-bar-and-vice method finally worked, but if you're not careful it will chew up the aluminum so as to be unuseable. Took a good deal of back and forth across the angle to get it to work.
Made F14-12R.
