6-5-2009 |
2.00 |
2nd wing spar piece + small parts layouts |
Cut out the second spar W10-05. Also laid out lots of small parts on my .090 sheet. All my flat stock parts are made with paper patterns glue-stick'ed to the aluminum. I leave the patterns on until I finish the edges with the files. I use a center punch to put a light punch in the surface of the aluminum at the centers of all the holes in the patterns. Only when all of that is done do I remove the paper pattern. |
