Date:    1-18-2020
Number of Hours:    0.00
Brief Description:    Cabin Heat 2.0 Testing
January 18:
Today was much colder outside. 22 deg F on the ground, and in the teens in the air. Usually I would not go out in these low temps, but wanted to get in another test. This time I opened the intake hole in the engine baffle to 100% open.
- Taxiing I measured over 70 deg.
- Climbing out the OAT was 18 deg F. Saw 72 deg.
- I tried closing the flapper valve on the firewall and the temperature
dropped to 50 F. So you can't get more heat by restricting the flow
at the firewall valve.
- Level at 3,000', 2,900 rpm, OAT 18 F: temp was 60 deg.
Today was a colder day, so hard to compare to the previous flight, But I think the next test will be to neck down the intake to where it was on the previous test, and then start playing with the setups downstream.
