7-4-2017 |
0.00 |
Helicoil for stripped bolt hole 1 of 2 |
During my annual inspection I found the lower bolt hole in the left head (#2 cylinder) that holds the exhaust flange, was stipped. So I ordered a helicoil kit and fixed it today. The exhaust flange had to be moved to the side to do the work, so all 4 exhaust bolts had to be removed to slide the exhaust over. After that it took 10 minutes to do the work. |
