Date:    6-8-2017
Number of Hours:    0.00
Brief Description:    Changing to Top Oil Cooler 2 of 3
- In photo 1 you can see I stuffed paper towels in the upper part of the engine mount, where the top magneto is. All of that area is open to the back of the engine and I didn't want ANY metal or shavings going down there!
- Photo #2 shows the cuts at the rear baffle. I left a half inch or so of rubber baffles sticking out beyond the metal.
- Note that the #2 spark plug wire had passed through the rear baffle, but was not cut away with the center section. So the wire is laying loose in the photo. A new hole will need to be drilled to the right to install the rubber grommet and spark plug wire.
- In photo #3 I'm using a cardboard template to get the initial location and trimming done for the new baffle.
