Date:    6-17-2014
Number of Hours:    0.00
Brief Description:    Fiberglass work
I did a little fiberglass work tonight, too. The top and bottom cowls don't align, so I added some fiberglass filler to get the levels to match. Photo 1 has peel-ply over the work.
The tabs that hold the fasteners for the center/front cowl, had the fastener holes off center. So I decided to glass them and start over. I filled the holes with fiberglass mat (the thick kind used as filler), put one layer of glass over it, and then 3 layers backing it up. This should fill the hole and give it some more purchase for the fastener.
